Old 03-16-2010, 11:20 PM   #8 (permalink)
Old Tele man
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
Originally Posted by MadisonMPG View Post
I am not advocating using higher octane. I am asking: Does using higher then approved octane (Premium) shorten the life of an OBDII engine meant to run on 87 (Regular)?
...two letter answer: no.
...octane is a "knock-limiting" value and basically nothing else! So, using 91 octane ("Premium") in a car designed for 87 octane ("regular") will NOT damage it whatsoever.
...what can damage an engine, however, is using different fuels containing god-knows-what-kind of additives that don't burn cleanly.
...this has NOTHING to due with octane--but is, too often, one (of many) false claims made for the additives--but rather the "left-over deposits" from faulty combustion, which CAN by themselves cause "glowing carbon" deposits which CAN result in pre-ignition and cause damage (if the computer can't yank the timing back quick enough).
...read the WIKI explanation for octane, it should help you come to your own answer.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
