Originally Posted by AeroModder
<snip>I'm renting a 2008 Chevy Aveo. I can't see the turn signal indicators, half of the fuel and temp gauges, and the tops of the speedo and tach because they're hidden under the top of the steering wheel. A very poorly designed car, in my op<snip>
The
Aveo has tilt steering wheel, standard. Look under the steering column. You probably didn't notice because you're only renting.
