The Ninja is a twin and the Rebel is a single cyl. Finding a tourer set up would give better coverage and let you keep the upright position. Unlike a bicycle which can be easily adjusted to get a comfortable crouch, a motorcycle must change parts. I've found a variety of plastic locking work boxes by Stanley and Sterling. Look for something 28x18x14 inches. Taper back from the box 8-12 degrees to form the tail. If you are riding in a crouch the box would be shorter and make some side panels to come to the shoulders.
