Old 03-18-2010, 10:13 PM   #7 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Even if the hydraulic drive is less efficient than a manual or automatic transmission, it doesn't matter.
You can't consider a specific driveline part when the dynamics of the drive system are changed. With a hydraulic drive system, the fueled engine runs at it's most efficient RPM/load ALL THE TIME. Your car doesn't do that.
Even if the hydraulic setup were only 70% efficient, it would probably (most likely) still beat anything on the market currently, provided it would actually be built and work.
The Following User Says Thank You to Christ For This Useful Post:
Old Mechanic (03-18-2010)
