resistor mod
Thank you gents. Once I get through with class I'll try it out.
[edit] I finally got my homework done, and soldered a 4.7kohm resistor in. This is the same resistor value I used to modify my IAT sensor wire. In that case, it tricks the PCM into thinking it is 20* cooler outside. Good for hotter temps in the summer. Here is a picture of my solder job...
I had to cobble my picture together w/MS paint so I could shrink it.
Reason: got some time!
