Originally Posted by Ryland
because of the low hight of the peek of your roof (18") I still think you are going to be best off insulating your attic space, and even adding normal non powered roof vents, $50 later and you will have a well insulated, vented attic, keeping your ceiling cool, and adding resale value to your house, a white roof will also add resale value to a house in Arizona, because the shingles will last longer, and your cooling bills will be lower, white roof paint looks to be about $25 a gallon, and should cover 100-150 square feet of roof, last many years and it will never blow away.
I highly agree with everything said here. Insulation, vent fan, and
white paint. I suppose it depends on purity of the color, but white paint should reflect nearly the equivalent of a mirrored surface. It's cheap, easy, durable, and less likely to piss off the neighbors...and less conspicuous.
Since it's so dry there, I think a
swamp cooler could easily take care of all your A/C needs. Cheap to buy, run, and maintain. Not to mention, it'll help with the quality of life...especially the nose bleeds...
Originally Posted by trebuchet03
Wow, that Earthship thing is totally cool! Thanks for linking
Thank you Ed Begley.
- LostCause
