Old 03-21-2010, 02:57 AM   #10 (permalink)
greasemonkee
What part? There is an extra connector on VX only chassis harness.
The easiest thing to do is make an auxiliary harness for the extra Vx related items. Look at the Helms and you'll see which wires need to be shielded - generally O2 signals and ignition related lines. Ground one end of the shielding, preferably to the same ground as the other shield grounds, but do not stack the grounds.
