Old 03-21-2010, 03:37 PM   #10 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
jkp1187 -
Originally Posted by jkp1187 View Post
You lost your cruise control just by plus-sizing the tires? I've never heard of that before. What happened?
[EDIT: I mistyped in my above post. I meant when I changed my gearing, not my tires. This response is about changing *gears*]
(This is only intelligent speculation on my part, because I don't have the source code)
The OEM Saturn Cruise Control will only engage in the top gear. The ECU/PCM looks for a 5th gear MPH/RPM combination (or ratio?) that is above 25 MPH. Because I reduced my 5th gear RPMs, the ECU/PCM never sees an MPH/RPM combo that "qualifies" for CC. The end result is that the ECU/PCM ignores my CC request.
There was never an aftermarket for reprogramming Saturn S-Series ECU/PCMs, so it's not easy to fix.
CarloSW2
American Solar Energy Society
