Your on ecomodder, Home of the Open Source Cougar Controller. Y not use one of those?
It will handle 500A and all the way to 144V. You can use any voltage you want with it between 0 and 144.
For the cost of it, you will be less then the alltrax controller and have far more options to play with for optimal performance.
-Adam
