Old 03-26-2010, 11:26 AM   #74 (permalink)
88hf
EcoModder!
ratatouli - '01 insight
Well, depends on what you mean by obd2. I have both obd2a and obd2b ecu's so I could do either in case I pick up an ek to put all the goodies in. Right now plan is still on the crx. The obd2a ver doesn't require 2nd O2 sensor so its not even fully obd2a. I have all the original engine wiring harness and have spliced into 99 cabin harness. I'm going to do a 99 si dash swap as well, which I know is going to be a pain, but I've got the dash and I'm going to do it. Other than the 99 interior wiring and Vi-rs cluster, I also picked up a 99 Vi-Rs navi system last week. So, It'll be Vi-rs sweetness whatever car it ends up in. I have the electrical service manual for the 90 crx all photographed so if anyone wants a copy I could mail it on cd, but I don't have anywhere to put the 400mb of images online. I can make sections available or email if anyone just needs a certain section also. Also, have 88, 92, and 96-00 electrical troubleshooting manuals... but the 96-00 is available online already. Good luck with your project, maybe you'll be done before me. At first I was going to just throw it in and wire it up quick, but I've decided to make it nice. So its going to take time. ETA is looking like summer at some point. Doing a new lower crossmember with front engine mount, new poly mounts elsewhere, da front brakes, si axles, hf transmission. I know it won't be as quick as some people would like, but with 130hp I think the hf transmission will be fine.
