Old 03-28-2008, 09:59 PM   #19 (permalink)
LostCause
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Originally Posted by sharp21 View Post
Check out www.99mpg.com
He has an electric driven wheel built in to his modded Insight.
Look up three posts and there's your man...
I like the creativity of all these ideas, but with their complexity you might as well build a conventional hybrid system.
The belted starter/generator seems most promising. A motor is essentially attached to the serpentine belt. Power is sent through the engine into the transmission and out the wheels. Obviously it is not ideal due to the added loss of the engine, but it can't be beat for simplicity.
MD2000, how did you come across those Prius subpacks? Did you buy a whole battery pack and split it apart, go in with other people, or come across them individually? If you don't mind, what do you estimate the price of each subpack to be worth?
Originally Posted by basjoos View Post
I wonder if it would be possible to mount a pusher on a 1-wheel trailer using an in-hub motor. 1-wheel trailers have less length and don't have the problems with backing up and parking that a conventional articulated trailer does. The single wheel on these trailers is a caster, so you would have to move forward enough to straighten the wheel out before applying power to the in-hub motor.
If modularity is desired, why not create a unit that attaches solely to the hitch? A single drive wheel attached to a linear actuator could lower vertically to the ground. When it is no longer needed, it can be unhitched. The whole idea is that it is rigidly attached and extremely shallow.
- LostCause
The Following User Says Thank You to LostCause For This Useful Post:
dave77 (01-01-2010)
