Old 03-29-2008, 12:38 PM   #22 (permalink)
Silveredwings
Lurking footless halls
Silveredwings's Avatar
Orient Blue - '02 325Ci Convertible
If the same volume of air passes through a smaller cross-section or channel, the speed of that air will increase while passing through. It may be counter intuitive but the pressure at that same point will decrease (the Bernoulli Effect). Think of it as a venturi.
In the case of lowering an air dam and the ground, I don't think the volume will be the same as before lowering, since the gap is more of an orifice than a venturi. If the front of the car channels air under the car (unlike an air dam), however, the airspeed probably does increase and Darin has a good point Doesn't he always? .
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
