Old 03-29-2008, 05:52 PM   #1 (permalink)
extragoode
Oden - '00 Frontier Crew Cab
Pickups
90 day: 22.55 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 16.69 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
Solar Water heater
I was looking at some of the home ecomodding threads about solar water heaters and notices that they can heat the water up 140 defrees F and it struck me that that's about the same temperature the engine block heater I was looking at would do, give 25 degrees. The biggest problem I have with an engine block heater is that only works when I'm home. While I'm at work, it's parked outside. The water would be warmed by the time I was parking, it'd just need to keep it from dropping back down to freezing. Same concept as a thermos, but active instead of passive. I could put on a lexan hood and save some weight too. The other thought was to plumb it to the bed and set it underneath a clear bed cap, but that'd be a lot piping that could leak. What do you guys see as problems?
