Old 03-30-2008, 12:19 PM   #4 (permalink)
brucepick
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.92 mpg (US)
My guess is maybe a bad valve stem was the cause.
Valve leaked causing tire to lose pressure.
I'm not sure if it can go this way but - - -
Pressure loss causes temperature rise which causes heat built up due to expansion of air in tire. This causes increased pressure - until the rubber fails, then you lose the pressure.
I found a pressure gauge rated accurate to +/- 1 psi. From Accu-Gage company in Ohio or thereabouts, brass case, dial gauge. I found them by a web search so that works - but I bought it locally. Now made in China but they still say accurate +/- 1 psi. Nearly $15 but money well spent.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
