The '04 Civic uses a plastic bracket to hold the front plate on.
It screws to the bumper in front and underneath.
By removing the plate holder, turning it upside down and cutting off everything except the top (which used to be the bottom) plate mounting holes.
Then re-mounting it (upside down) the plate now goes under the bumper into the lower grill area.
Doing a little grill blocking and now it's bend backwards so it act less like a flat plow going through the air.
Looks better too.
