Old 05-03-2010, 08:25 AM   #20 (permalink)
jackbauer
jackbauer's Avatar
The only times i've seen that problem is when i've screwed up the config bits programming the micro or not seated the micro fully in the socket. First thing i'd do is check the micro is fully home in its socket.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
