Burping cooling system:
Depends on car, but the worst ever is the MR2. Front Rad, Rear engine.
On My Accord (long gone) (and on supras) I put the front end up as high as I can get it (ramps + jacks on my slightly sloped driveway) then I use my special Cooling system burping tool, which is a radiator cap with the pressure portion cut out/ removed. Fill it up, Start it/ warm it up, keep the overflow full, turn it off, keep overflow full, replace cap . end of story (excluding BHG's).
6 speed ALH TDI
