Map mpg tps mph
2000 Camry I4, 6+% oversized diameter tires. 205/70-15 Yoko Avid Touring S
TPS - constantly back off to get nbr lower
MAP - Manifold Absolute Pressure (Vacuum) The lower TPS, Lower MAP Higher
MPG
MPH because my speedo is off due to oversized tires
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
