hmmm. Interesting. One idea would be to dry the unit out and spray the control board with conformal coating to seal out any moisture. A likely area would be the crystal. Any disturbance to the tiny currents and voltages involved in the oscillator circuit may prevent the micro from starting.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
