Old 05-09-2010, 05:38 PM   #28 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Why couldn't an ecomodder use sheet metal or aluminum instead of flammable coroplast? On my Maxima the exhaust system is insulated (but not the cats) so covering the entire exhaust system and cooling just the cat should in theory be acceptable. I'm also considering installing ground effects on the sides and fronts then putting the underpan at that level which would keep the metal away from the heat, and assuming I leave enough air flow into the engine compartment it should be kept cool if I make it airtight.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
