>The 4 liter motors are infamous for oil leaks at the oil filter adapter(90* elbow)
you can buy the seal kit for it from your local dealer for ~ $10, just a couple of "O" rings.
very easy to replace
do it when you need to change the oil
>Valve cover gasket
Cork is OK
coat it with gasket adhesive (echoing Pete)
do not over torque ( the cork will actually squeeze out and you have nothing left between the hard parts)
>Power steering pump
probly the front seal
remanufactured pump ~ $75 at your local parts store
also easy to replace
use a catch pan
I recommend replace the belt at the same time (unless it is already new)
Have fun
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
