Old 05-18-2010, 10:51 PM   #85 (permalink)
kimer6
governor spring
Originally Posted by musichead View Post
dear kimer6
I read your note about kubota D1105 .. ex generator..
i have this machine.. and want to build a coffee grinder machine..
but the grinder spek need abou 2200 rpm..
i just want to know your experience on engine..
is that any way to increase rpm to 2200 without change any part (only adjust the engine)..
or on what rpm you can reach with this machine without change the part..
thank for your info..
i realy need your experience..
Sure you can get almost 3200 rpm just by adjusting the governor on the outside of the unit. 2200 should be very easy. Just back out the governor screws that hold the engine at 1800 rpm and move the throttle lever to increase speed. This should be very easy for you.
