Old 05-19-2010, 07:50 AM   #86 (permalink)
musichead
Originally Posted by kimer6 View Post
Sure you can get almost 3200 rpm just by adjusting the governor on the outside of the unit. 2200 should be very easy. Just back out the governor screws that hold the engine at 1800 rpm and move the throttle lever to increase speed. This should be very easy for you.
thanks for response kimer..
you describe on previous post that the kubota generator engine 1800.. need difference governor than 2 fork type on kubota genset 1800 to make it like industrial type on 3600rpm..
and you spend $1000 to make the change...
so.. i little confuse.... why you spend a lot of money if the we can modify the rpm from 1800 to 3000 like in the quote..
i am far away from my engine that located on my village...
so need know the theory first..
wait for your reply..
thanks kimer
