Old 04-05-2008, 08:02 PM   #16 (permalink)
Peter7307
Check the power steering fluid container too.
These can crack right where the hose slips over the tube and it is usually due to trying to tighten the hose clamp and pushing too hard causing a crack in the container.
It can be hard to spot and many blame the hose.
By the way clean off with a rag and wipe talcum powder over the clean areas to help spot the source of the leak.
Cheers , Pete.
