Old 06-25-2010, 07:24 PM   #10 (permalink)
Old Tele man
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...Swamp Cooler Theory 101:
eqn 1: E(s) = ( DBD / WBD ) = (T1 - T2) / (T1 - T3)
...where:
E(s) = Saturation Efficiency, actual change divided by maximum possible change.
DBD = Dry-Bulb Depression, air temperature change from HOT to COOL, actual.
WBD = Wet-Bulb Depression, air temperature change, HOT to COOL, maximum possible.
T1 = Outside (or inlet) HOT air temperature.
T2 = Inside (or discharge) COOL air temperature.
T3 = Wetbulb temperature, maximum adiabetic air cooling possible.
...for example, if T1 = 105°F and T2 = 73.9°F and T3 = 66.1°F, then the saturation efficiency E(s) would be 0.80, or 80%:
E(s) = (105.0-73.9)/(105.0-66.1) = 0.80 x 100% = 80%
...unfortunately, that E(s) value is for Aspen Excelsior, not a FRAM™ paper automotive air filter, which probably has an E(s)-value of ~ 0.5 or less.
...never the less, let's backsolve the above equation to see how "cool" the air going into the engine (ie: T2) would be with E(s) = 0.5:
eqn 2: T2 = T1 - E(s)*(T1 - T3) = 105.0 - 0.5*(105.0 - 66.1) = (105.0 - 19.4) = 85.6°F ...a (theoretical) temperature reduction of 19.4°F.
...if you know the relative humidity (RH%) values of T1, T2 and T3, Eqn 1 becomes:
eqn 3: E(s) = SQRT[ (rh2 - rh1)/(rh3 - rh1) ]
...where:
rh1 = relative humidity at T1 of the inlet (outside) air.
rh2 = relative humidity at T2 of the discharge (after the wet filter) air.
rh3 = relative humidity at T3; theoretically 100%, but practically less than 80%.
...so, because of the HUGE volume of air drawn by the engine through the air filter, a large amount of water is required to raise rh2. For instance, in the first example above, the outside air would be: T1 = 105°F @ rh1 = 12% and the inside air (going into engine) would be: T2 = 73.9°F @ rh2 = 68%.
...unfortunately, THAT's gonna take a LOT of water, especially if you're driving at freeway speeds (higher RPMs) for any appreciable time...literally, gallons-per-hour!
...and, here's the equation for calculating "how many" gallons-per-hour (GPH) of water you'd need:
eqn 4: GPH = [CFM*WBD*E(s)] / 8700
...where, 8700 is a conversion factor based upon (a) 8.34 lb. water-per-gallon and (b) 1043 BTU-per-pound of water. CFM is a function of engine displacement (CID), volumetric efficiency (~ 80%) and RPM:
eqn 5: CFM = (CID*RPM*0.8) / 3456
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Last edited by Old Tele man; 06-30-2010 at 12:06 PM.. Reason: added GPH and CFM equations.
