Old 04-06-2008, 02:23 PM   #1 (permalink)
WTFM8
Driving God
WTFM8's Avatar
Yoko - '97 Civic HX
90 day: 40.04 mpg (US)
Big Red - '91 CB750 Nighthawk
90 day: 46.29 mpg (US)
Fiddy - '01 SR 50 Elite
Last 3: 97.85 mpg (US)
Trolly - '01 7200 Multitrack Hybrid Road
90 day: 22.14 mpg (US)
Coasting in gear vs. neutral (fuel cut feature)
So, yesterday I was messing about with my scangauge and made a breakthrough: when I coast down hill in neutral (no engine off yet for me) my car consumes gas at idle level, but if I coast in gear taking my foot all the way off the pedal, after a few seconds my gallons-per-hour readout hits 0.00, which leads me to believe this is closer to EOC than when I go into neutral down hills. My question then, is how does this actually compare to other methods to boost MPG down hills? I assume cutting the engine and going into neutral would yield a greater increase in speed down hills, and therefore higher MPG than my coasting in gear, but the SG reads 9999 MPG until I use the throttle again so I have assume this could be better than engine on coasting.
This might not be anything new to some of you, but I had no idea my car was cutting fuel when coasting in gear.
