Originally Posted by Chris D.
does it know the size of your fuel tank, your injector pulse rates, voltage to the pump, regulator settings?
Tank: Yes - you tell it
Injector Duty Cycle: Yes
Pump Voltage: Implicitly (but this doesn't matter so much)
Regulator Settings: Implicitly
It knows no more than the on board engine management does
It's also calibrated by the meat person operator @ fuel up. The more you use - the more accurate it gets
Mine has been spot on for quite a few fill ups now
LinearLogic did an awesome job programming the thing
