Old 07-10-2010, 09:30 AM   #159 (permalink)
MechEngVT
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.8 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
Originally Posted by cfg83 View Post
Gasoline with 250 g/kW·h BSFC :
1 / ( 250 * 0.0122225)
= 1 / ( 250 in g/kW·h * 0.0122225 in kW·h/g )
= 1 / 3.055625
= 0.32725 "efficiency"
Is this the way it's supposed to be? Are there units for this?
That's correct; your end result is the percentage. In your calculation the engine is 32.725% efficient, with percentages being unitless ratios.
Note that diesel has lower heat energy per pound than gasoline. Diesel fuel is 7.1 lb/gal density whereas gasoline is just over 6 lb/gal. Diesel has more energy per gallon as a result, yet less energy per pound. Diesel engines with comparable BSFC ratings as a gasoline counterpart are therefore more "fuel efficient" in a L/100km or MPG aspect despite requiring equal energy per power output.
