The front really isn't as important as the back to be honest. Relatively small changes to the radius transition from the bumper cover to the hood keep the airflow attached. The same can be said for the transition between the bumper cover and underside (assuming your using a bellypan) and sides of the vehicle.
If you post some pictures we can recommend some things probably.
