Old 04-08-2008, 01:25 AM   #3 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Hi -- cool (I mean Hott) idea -- and welcome to EM.
First, I would make sure that you've done your research on the ideal temperature. I've experimented with WAIs, HAIs, and CAIs for the last 3 years. For my Honda-based engine, the target is 100F.
I commend you on the design, but perhaps a simple tube to the exhaust manifold area could yield excellent results.
My WAI this Winter was essentially a 3-foot section of flex-pipe exhaust tubing, with the air source being just above the exhaust manifold. It was simple to install and relocate to source cooler air for Summer (which is essentially 90-100F as temps heat up). As ambient temps warmed up, congested traffic yielded 140-150F intake temps (which is bad -- the ECU dumps more fuel to cool the charge, and retards timing to prevent detonation).
Best FE to you and welcome to EM!
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
