If cold is a concern, there are plenty of heater cores available, and you can leave the grill closed longer if you use coolant to heat the cab. I wouldn't turn my nose up at reusing any extra heat if it's extra cold. given how prevalent liquid cooled cars with heat are, that's easily accomplished.
