The two piece belly pan I have installed is the one pictured earlier in the thread. It isn't full length but closer to about 2/3rds length (or maybe 1/2). I have raised the rear rake up about 3/4 of an inch from what is pictured in the photos to limit grounding out on short but tall speed bumps when I have passengers.
With just the belly pan and synthetic oil as the only two mods from stock, I pulled 44.2 mpg on my last tank. I realized yesterday when I went out that I had been a bit lax in checking my tire pressure and the fronts were down to about 32 from my usual 44 psi. Topped them back up and have hopes to clear 45 mpg some time this summer before it cools back down.
Have a bunch of gas receipts sitting around and I'll try to update my fuel log shortly.
