Old 08-07-2010, 10:09 PM   #20 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '010 Prius III
Originally Posted by Wonderboy View Post
Any suggestions on this little problem would be appreciated. You can kind of see in the next two images what I did to combat it - I just cut small pieces to plug up the hole, but its still pretty blunt and perpendicular to airflow.
You could make a new set of skirts with an additional area as shown by the red lines in the following pics. They would be fitted to come to a point at the bottom of the V in the side of the body. This should give you a smooth transition to the outer surface of the skirt.
