Our vacuum uses water as the filter, similar to air filters that use oil, like the old VW's have, they works really well, and can hold alot of crud, and you just dump the water when you are done, if you used oil for your filter you could then have a centrifuge filter at home that spun the dirt out of it, and use it again and again.
