Old 04-10-2008, 05:17 PM   #2 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Likely it's a loose heat shield with the exhaust system -- from the header on back to the muffler.
Are you able to give more detail? Can you park the car, let it idle, and listen from the outside?
RH77
Originally Posted by jesse.rizzo View Post
Hi all. A few days ago my car, 2001 Hyundai Accent, started making a clattering noise. It happens even when the car is idling, so I guess that rules out anything with the drive train. I at first suspected detonation, but I've heard that described as more of a pinging noise, and this is definitely a clatter or maybe rattling noise.
I'm not getting a CEL, and according to my scangauge, everything is normal, except the intake air temp. It read a intake air temp of 99F on a 50F day. I'm not running a WAI or grille block. Any ideas or suggestions of things to look at would be great. Thanks.
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
