Old 04-10-2008, 09:17 PM   #4 (permalink)
LostCause
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Great articles SVOboy and tasdrouille.
What I don't understand is how the heightened compression ration will be used. If knock isn't going to be eliminated by direct injection or some other technique, is there something I'm missing? I suppose an engine may not knock under low load (cruising) and only under acceleration...
I also wonder why variable compression can't be achieved with variable valve timing. Toyota's "Atkinson" cycle engine uses late valve closure to reduce the compression ration, so why not apply variable valve timing to choose high, low, or gradations in between as technology becomes more advanced. Seems simpler than linkages, moveable heads, variable height pistons, etc.
- LostCause
