Overinflation would be over the car's recommended value. It may be a good way of saving fuel, but it does pre-maturely wear tires (but I am sure that someone will say that it doesn't, as I said above this is a very tough argument.) It also causes suspension to wear prematurely as well as drivetrain, but once again someone will dispute that. I also believe (this is something that I know will be questioned, read previous post) that it does provide significant safety hazards under certain driving conditions. Argue away, like it has been in other posts and for the same reason that I told the OP that this may be the biggest waste of his time. I will keep my inflations within reason.
