Old 08-23-2010, 07:43 AM   #425 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
Originally Posted by thecheese429 View Post
Basjoos, I have a question about the construction you used. It looks like you used a lot of coroplast, then aluminum sheeting, held on with rivets or screws, but what is that glue/filler type stuff you used on the coroplast? I guess it is the same stuff you used in the body gaps?
At this point, the only Coroplast is on the belly pan, side skirts, and front wheel air splitters where I need the flexibility to pop back from impacts that aluminum sheet doesn't have. The filler/seal stuff is mostly white exterior grade latex caulk from Lowe's, although I did use epoxy putty on some locations where I needed thicker layers than could be done with caulk.
aerocivic.com
