Old 08-23-2010, 11:36 PM   #136 (permalink)
bengry
Lean burn - '89 Civic Wagon DX
Elle - '03 Element EX AWD Auto
why not fab a mounting plate to get any old civic trans onto the engine directly kicking out the ima and then bolt a flywheel and clutch directly to the output of the motor.
You see plates like this from bisimoto to mount a h or b series motor to the easily available d series transmission.
I am not sure if the engine management will run the engine with out the ima bits.
Perhaps a stand alone engine management that would be tunable for lean burn and to possibly supplement a small turbo to help out with acceleration.
