Old 08-24-2010, 03:48 PM   #14 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Kristoffer -
Originally Posted by grillbritt View Post
I Have one Smart NOX sensor from VDOsiemens from a Scania. does anyone knows how you can use it? i dont find any information about that, its 4 pin probably CANH, CANL, Ground, Supply.
Regards Kristoffer
If the NOx sensor does not require special communications with the rest of a CAN system, then maybe you can just measure the voltage. Get a baseline voltage while running the engine under OEM specifications. Get another reading under lean-burn conditions. The key will be mapping the voltage to NOx values.
However, it is a BIG assumption that the NOx sensor will operate in such a simple way. Here's more info on CAN :
Automotive CAN Network Diagnostics
CarloSW2
American Solar Energy Society
