Old 12-10-2007, 07:09 PM   #3 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by Lazarus View Post
Did you not just replace the t-stat? Do you have any other parameters. If it's the cooling fan you should be able to tell by where the water temp is. I've got mine blocked completely and if never comes on in cruise. The highest temp during a climb is 209 and the fan comes on at 211.
The stat was changed over a year ago -- so nothing really recent there. I noticed during the summer that coolant temps would be reported as 216-224F from wherever the sensor is located. The fan would kick-in at 220+, but never went higher than 224. Temps aren't close to that now -- 215 at the most, but 200 at cruise. Lowest ambient has been 15F with freezing rain. On a side note, big time ZR+ tonight -- accumulations up to an inch of ice!
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
