wow.. building from scratch?? I hope you have the facilities to cut and weld 1/2" thick steel with reasonable precision!
honestly I don't see this working out to be any cheaper than buying one and converting it. 90% of that metal is going to be the same. unless you have some wild twist to put on it! mount this in the bed of a 4x4 truck instead of treads?
