Old 04-13-2008, 10:29 PM   #12 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
MPG -- MPH
FIA -- TPS
MPH - Speedo is inaccurate; VSS accurate per GPS
FIA - Always monitoring intake air temps
TPS / Variable Slot: Throttle position (for me) is often used over MPG, especially in hilly terrain: I pick a TPS and stick with it on certain routes, and with the automatic, hitting that 10-11 reading to essentially bleed-off speed at high FE without compression slowing.
Sometimes in the TPS spot: FWT for cold starts; VLT for engine-off operation...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
