Thread
Nissan Versa Base 1.6
09-25-2010, 12:37 PM
98
permalink
skyl4rk
Coasting Down the Peak
Toyauto Pickup
- '94 Pickup 2WD
90 day:
36.32
mpg (US)
Versa Base
- '09 Sedan 1.6 Base
90 day:
41.69
mpg (US)
The frame is welded up of 1-1/4" square steel tube. It fits in the hitch receiver tightly, with just a little play.
A plywood base will be bolted to this frame. Then a body will be assembled from light plywood glued to the plywood base. I will attach nylon straps to the interior of the tail and tighten the tail up to the top of the trunk of the car. With a connection to the frame of the car through the trailer hitch receiver, and two nylon straps holding the top close to the car body, this one should not self-destruct. I will also make sure there are no large gaps to catch the wind.
Nissan Versa Aeromods
skyl4rk
View Public Profile
Send a private message to skyl4rk
Find More Posts by skyl4rk
