Old 10-04-2010, 11:03 AM   #37 (permalink)
Dave's Civic Duty
Mater - '98 3500 Dually
Wilber - '99 Corolla LX
Minyatta - '93 Miata MX-5
Originally Posted by nubbzcummins View Post
Slowmover: Do you think my numbers are good considering my setup? I'm only 1-1.5mpg less than your lifetime mpg numbers. Not shure of the terrain you drive but my commuting is through rolling hills in the piedmont of NC. I will be playing around with different power settings to see if I can gain any mpg numbers. I may start limiting my power with the Smarty POD to lessen fuel consumption during accel and pulling grades.....Also started using water injection.....Oh...An aero bed cap is in the works too!
What are you using for a Lift Pump. You may have a CP3 becuse you have a common rail, that w/ a manual trans would be the way to go. I do have an auto w/ the vp44.
Are you using a Scan Gauge ii? ood luck & continued success w/ your CTD!
Dave
