Old 04-15-2008, 04:23 PM   #9 (permalink)
jwxr7
jwxr7's Avatar
the metro experience - '94 metro 4 dr HB
90 day: 71.84 mpg (US)
got the head tube bearings cleaned, regreased and installed. Also did the same with the crank bearings.
Ran into a little problem with the bottom bracket though. I am using the crank and bottom bracket off a different schwinn because the original that was on the Trak was the old heavy pinned style. The tube that houses the bottom bracket must be a bit wider than the one on the schwinn because by the time I snug up the bearings properly there are only like a thread or two sticking out on the left bearing cup to allow the jam nut to thread on. Not sure what i will do about that. I could mill the face of either side to narrow the tube, but that would be a mess to try setting up properly with the long frame and all.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
