Thread: new ebike!!
Old 04-15-2008, 03:42 PM   #12 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Originally Posted by lovemysan View Post
I'm not sure what the lowest safe level of charge is. The 25-49% light was on. I need to get a DWM to check for voltage sag.
I'd definitely recommend a DVM or build/buy an equivalent LED meter.
Not sure if sealed battery chemistry is the same as flooded (doubt it), but the safe lower limit under load for a floodie is 1.75v per cell, or 10.5v per 12v battery.
Below that, you run the risk of reversing a cell and ruining the battery.
Generally people don't recommend drawing the floodies much below 50% for maximum cycle life. And avoid letting the batteries sit partially discharged.
Speaking of which that reminds me it's time to top up the ForkenSwift's second pack (sitting in the garage). I do it once a month.
