I hooked up the antenna wire to the rear window defogger. It has great reception. The defogger is disabled now (disconnected at both ends) but its not an issue because the tint on the inside of the windows seems to prevent that from happening. The defogger button and circuit and be reused for other purposes. I use it to go between a FE and power fuel table in MS.
