Old 10-09-2010, 10:02 PM   #10 (permalink)
Originally Posted by cfg83 View Post
tjts1 -
I always wanted to do that but never got around to it. I pulled the fuse of the rear defogger in preparation, but I didn't do the next step of figuring out where to hook into it. I was going to hook into one of the connectors where the fuse was, but I have to make sure I don't connect it to the "hot" connector, or I'll fry my radio.
I connected the antenna wire directly to the defogger on the window. It has 2 small plugs, one on each side of the window. Other cars might be different but usually there is a pretty simple plug glued to the glass.
good luck
