Well I got the back wheel off , cleaned and repainted. Also replaced the wheel bearings , sprocket carrier bearing , sprocket , brake disc and brake shoes. All in the back end of this bike was in bad shape. Cleaned up the swing arm a bit but this is a conversion not a restoration. I had to make a simple tool to push back the caliper piston. Just a piece of 50x10mm flat steel with a 8mm tapped hole for a bolt. worked great.
I've been wrestling with the battery choice ever since i started the project and came to the conclusion that building a lead acid bike would , quite simply , be a waste of time. My first thought had been odyssey pc680 agm to keep the weight down but the range would have been abysmal. Anything bigger would have yielded a two wheel battering ram.
I bit the bullet and purchased some headway cells for testing and have been blown away with the performance. Based on that I made a further purchase of a quantity of 16 off 16ah cells to begin sizing up a pack. Plan is to start off with a 20s2p pack and work up to a 30s4p. That would allow for at least 600amp peak discharge.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
